Continuing the thubnail building for 1 files
Bongo
Post by Bongo »
I deleted my thumbs.db and created again. Now is ready but when starting PSU comes:
I've already tried that:
But nothing is found.
What can I do?
Regards, Bongo
Photo Supreme V2024 Single User Edition, Windows 11.
Re: Continuing the thubnail building for 1 files
Might be worth checking "States|From repository|Possible corruption", if there are any I delete from database and then scan and import missing files, usually fixes the problem.
Bongo
Post by Bongo »
Thanks for the suggestion.
But the result is empty.
Regards, Bongo
What about the menu Tools/ Build Missing Thumbnails and Previews?
Bongo
Post by Bongo »
RobiWan wrote: 17 Dec 24 21:42 What about the menu Tools/ Build Missing Thumbnails and Previews?
Thanks for your answer.
When I do this, the process display works. After the restart, the message "Continuing the Thubnail Building for 1 Files" comes again.
I just can't find it.
@Hert
Do you have a solution?
Regards, Bongo
xcalvov
Post by xcalvov »
I suffer also from the same issue since a couple of weeks. Besides, the system is quite unstable and freezes frequently forcing me to close and restart. I don't know if the thumbnail issue is the cause of the freezing problems. My system is up-to-date to built 2.6703
