Thumbnails from .THM rendered with wrong colours
fabrizio.giudici
Post by fabrizio.giudici »
While they worked well before PhotoSupreme 2024, as you can see below (the small Preview window shows the .THM file) they recently started to be rendered with over-saturated, too contrasted and “cold” colours. I thought that it was related to the colour profile in the .THM files, but switching from Adobe RGB to sRGB doesn't fix the issue.
Screenshot 2024-05-28 at 14.16.40.jpg (368.68 KiB) Viewed 3229 times
Photo Supreme + Capture One
http://stoppingdown.net
Re: Thumbnails from .THM rendered with wrong colours
Check if you enabled color management for thumbs/previews
Check the color profile in the metadata
Check if there are edits from a 3rd party tool (c1 cos file or Lightroom or DXO dop file)
fabrizio.giudici
I suppose it's "Color Mangement"/"Use color management to generate thumbnails (slows down)", right? It's enabled.
The embedded profile in the .THM is sRGB IEC61966-2.1 (checked with macOS Preview and exiftool).
The thumbnail is directly exported from Capture One (only renamed).
