When I try to use Geotagging thumbnail, I get
"Small problem... An error has occurred
Google Maps did not load correctly on this page. For more technical information about this error, please see the JavaScript console."
at the place of the map ....
where is the javascript console ?
what is the reason of this bug ?
[edit Hert; changed title]
Google Maps does not work
Re: bug report : google map does not work
Check your Google API key in the Google API Console.
1. Google requires that you have a valid payment method stored. Make sure that the registered payment method is still valid.
2. Check your API key restrictions and check if that is still valid
Thank you for the answer.
You are right : my API key was no more valid. I created a new one and it is OK now.
Problem solved
Problem solved
