Some menus not working with latest update (macOS)
fabrizio.giudici
Post by fabrizio.giudici »
Hello.
One month ago I upgraded to PSU 2024, no issues. After the latest update, some menus are no longer working. For instance:
* activating the filter and trying the "FILTER", "Label" or "Type" filter I see the submenu (e.g. in the case of "Type" in my case "All types", "All ARW", "All DNG"), but none can be selected (the menu just stay open even if I clink on an item). Menu items do change colour when the pointer passes over them, though.
* In the "Details" tab, the "Profile" menu opens, but no menu item can be selected.
macOS Ventura 13.6.6.
Photo Supreme + Capture One
http://stoppingdown.net
fabrizio.giudici
Re: Some menus not working with latest update (macOS)
I see also the menus "Country" and "Country code" in the "GEO tag" panel. At this point I'd dare to say that all drop down menus are involved.
wesstl
Post by wesstl »
I'm having the same issue when filtering a tab on macOS Sonoma.
fabrizio.giudici
Upgraded to build 6342, problem fixed.
