Is there a way to do this that actually works? I have a profile that contains copyright and contact info that I apply on import but, for some reason, the last import during apply it. I think the import hung up, requiring a restart of PSU. This is in the newly updated 2024 version on macOS Sonoma. When I noticed the data was missing I selected the image, clicked Details, selected my saved profile, scrolled to the bottom and chose Apply to full Version Set, and clicked ok. Sometimes appears to happen but when I select the files no data is applied. I had to use a different app to apply the data and then have PSU read it. This didn't work for me in 2023 and it doesn't work for me in 2024 liked I hoped it would. What am I doing wrong?
P.S. If the import had worked correctly I wouldn't have to do this.
Applying Profiles After Import
Re: Applying Profiles After Import
Pardon my typing...broke my arm so I only have one good arm.
Try to edit the profile and make sure that the operations are set correctly (the replace/append/delete markers). If that doesn't help, try to recreate the profile. You can edit a profile by right clicking on it in the Image Details its Profile dropdown
