Script to output all catalog labels to a text file
Roman
Post by Roman »
Has anyone developed a script to output all catalog labels to a text file so that you can use a text file comparison utility to identify differences in the catalog structure between two PS instances?
The "Export Import Catalog Structure" script produces a binary files that are not suitable for this method of caparison.
I am after an output similar to that produced by the "Find Duplicate Labels" script. This script only outputs duplicate labels, but I wish to output all labels. I thought I could modify the Duplicate Label script to do what I wanted but it is proving to be beyond my capabilities, and life is too short.
If anyone can help me out I would really appreciate it.
Roman
Re: Script to output all catalog labels to a text file
No script required - this will do it:
Roman
Post by Roman »
Thanks Mike, exactly what I was looking for.
