Export to folder as jpg
Sigi
Post by Sigi »
I have just tried to use "Export to folder as jpg" with a tiff file, never tried that before.
to my surpise the tiff was exported. I expected that the tiff with be converted to a jpg and that jpg is exported.
Is this a bug or normal?
Sigi
Re: Export to folder as jpg
I don't know of a feature called "export to folder as jpg", maybe it is a self created transfer/sharing profile?
There is a "Copy as JPG to Folder" and I tried it with a TIf which works fine
Either way...the file naming in the profile is what determines the output. Make sure your profile uses the JPG extension in the naming definition.
Sigi
Post by Sigi »
You are correct, there is no "Export to..." I have used "Copy as JPG to folder" on a tiff file.
I expected a jpg on the desktop but it just copied the tiff file onto the desktop.
I assume this is not the way it should be.
Make sure that the profile is correctly using the JPG extension in the naming (right click on the profile to edit it)
