Build 4940: Batch "Rename File" Raised Errors
Link648099
Post by Link648099 »
Just updated to Build 4940 and started getting these errors when I batch rename files. The program overall seems to be extra buggy now too. I've seen it hang on versioning and saving metadata to file too.
The batch rename problem is happening on both my iMac (intel) and my MacBook (M1 Pro).
Currently compacting the database and thumbnails to see if that helps any.
Screenshot 2023-07-18 at 1.46.05 PM.png (267.93 KiB) Viewed 6548 times
Re: Build 4940: Batch "Rename File" Raised Errors
Is there a way to downgrade to the last version before 4928 ?
I have had issues since that upgrade and first reported them here:
viewtopic.php?t=33323
The issue was then moved to viewtopic.php?t=33474&start=15
Built 4940 was supposed to fix it.
Link648099 wrote: 18 Jul 23 18:59 Just updated to Build 4940 and started getting these errors when I batch rename files.
Please update to build 4942. You can download it from the website or Control Panel
Link648099
Hert,
Thank you! Just updated to 4942 and the renaming error seems to be fixed!
