I have used PSu and catalogued all the photos and videos in c:/pictures.
What is the difference between the importing using following procedures: where both point to the same c:/pictures folder?:
• Hamburger > Import to Catalogue
• Hamburger > Import Folder
hip
Importing Photos to Cataloge
Re: Importing Photos to Cataloge
Import to Catalog is typically used to copy/move and then import files using configurable settings.
Import Folder imports files as-is from the folder you select.
Also read the Cataloging manual by selecting it from the ? icon in the left sidebar
