5x4 Aspect Ratio
wesstl
5x4 Aspect Ratio
Post by wesstl »
Is it possible to filter by 5x4/4x5 aspect ratio? I was a large format guy back in the day and really liked the format so I still crop that way often and would like to filter by that on occasion. Seems like a pretty common crop/format so I'm surprised it's not available. Thanks
Re: 5x4 Aspect Ratio
There's now a Aspect Ratio 5x4 entry in States -> From Repository
Aspect Ration 5x4.png (97.36 KiB) Viewed 16816 times
wesstl
Post by wesstl »
Thanks. Never looked in that section before. Very helpful.
HCS
Post by HCS »
Hert wrote: 07 Mar 23 9:59 There's now a Aspect Ratio 5x4 entry in States -> From Repository
I was looking for that option, but i don't see it in the States tab in my version 4981 (PostgreSQL on Windows 10). Is something missing, or do i need to take some action first?
Could be that you have the repository disabled in the preferences (Other Settings)
HCS
Post by HCS »
Hert wrote: 16 Sep 23 8:25 Could be that you have the repository disabled in the preferences (Other Settings)
Yes i did!
Thanks for that quick diagnosis, i didn't realize i had it turned off. Must have thought it belonged to the Google API settings (did turn those off).
Great, now i can select my 4x5's quickly :D
yar
Post by yar »
For me PSu does not show any submenu under States > From Repository. What can be wrong? The repository is enabled in the preferences.
PSu personal 2023.2.0.5022 on Windows
Best,
Alex
Could be that you have blocked Photo Supreme from accessing the internet. Check your firewall.
yar
Post by yar »
Hert, thanks for the suggestion. I have checked the firewall settings and PSu is not blocked. Also, in Filter menu filters from the repository are shown.
