Can I stop PSE from writing metadata directly to tiff files?
Bobbert
Post by Bobbert »
It takes a long time to synchronize my large tif files. Is there any way I can forces PSU to use xmp files instead?
aaronj
Re: Can I stop PSE from writing metadata directly to tiff files?
Post by aaronj »
Synchronization Settings->XMP Storage Location set to 'Always as a sidecar file' presumably accomplishes what you want. It isn't file type specific, but you could change the option and manually save to other types if you wanted to write into other file types and not just universally to XMP sidecar files.
You could also deselect 'Automatically write out Catalog changes to the image file' and manually trigger writing at convenient times with either Tools->Save Metadata to File... or Ctrl-S on one or more specifically selected images. I do this for especially when I'm making multiple changes in a row to images and I don't want to be doing a bunch of unnecessary write operations for each change.
Bobbert
Post by Bobbert »
I don't seem to have that option.. see attached images. Not sure what I should be selecting here
Untitled picture.png (54.86 KiB) Viewed 17573 times
Untitled picture2.png (19.66 KiB) Viewed 17573 times
Open the drop down list for "XMP Storage location" then select "Always as sidecar file" rather than the standard option.
Bobbert
Post by Bobbert »
Thanks, much appreciated
