what does a very-dim-catalog label in ctrl+F list mean?
andrew.heard
Post by andrew.heard »
From Categories > ctrl+F > sometimes the list contains barely visible labels - what does these results signify? Whatever it means, I suggest the labels are slightly more visible (for months before writing this post I had actually thought the results were totally blank!). For example ctrl+F "sign" displays a list with 6 entries as shown in the screen capture, the top 4 of which are barely visible in addition to "school sign" & "sign".
20221227-145320-Photo Supreme _ database photosupreme.cat.jpg (23.12 KiB) Viewed 4263 times
Thanks for any help, and happy new year.
andrew.heard
Re: what does a very-dim-catalog label in ctrl+F list mean?
Some further info during an intensive cataloging session...
I have a top level category named "other-metadata". On further examination, it appears that any ctrl+F results which relate to this category are very dim. For example I have a nested category other-metadata > theme > accident, as shown below. When I type ctrl+F > accident, the single item in the list is as below:
20221227-153441-Photo Supreme _ database photosupreme.cat.jpg (19.33 KiB) Viewed 4256 times
Does this suggest something inconsistent with the database? I have done a compaction.
Don't think I have ever seen that ?
In mine People, Events and Objects are all Bold font, whilst Places, Styles and Misc are all normal font, but nothing like your pictures at all.
andrew.heard
cheers Geoff. I'm 90% sure it's related to the top level "other-metadata"...
The "slightly visible" is the see-through of the menu. What you see slightly visible is what is behind the menu.
Maybe the text is being wrapped? What happens if you widen the left panel?
Could also be that you have special characters (like line feed) inside the label name that causes wrapping in the drop down. Try this: edit the "accident" properties, select all text in the name field (Ctrl-A) then re-enter the text. Do that for its parents too. That rules out special characters.
If that too doesn’t help, can you share a screenshot for the label properties and for its parents (including the new category default). Tia
andrew.heard
thanks for your suggestions Hert & happy new year
well spotted! confirmed
no change (all the labels are intentionally short)
is top level category "other-metadata" OK given ctrl+F "physical" works (& no text wrapping):
20221229-082145-Photo Supreme _ database photosupreme.cat.jpg (41.31 KiB) Viewed 4085 times
it doesn't appear to be
I re-entered "accident", parent "theme" and category "other-metadata" but it made no different
screenshots for the label properties and for its parents
I'm not sure what this is, sorry
andrew.heard
Just a quick progress report on this topic: Hert identified there was some "cache table that wasn't filled correctly" in a prior database upgrade. Hert was able to fix my 500MB photosupreme.cat.db & it all appears to be working again now. Great support. Happy new year to all & especially Hert.
