use ITPC tags in the Category browser
mdebokx
Post by mdebokx »
I’m migrating from the Windows platform to MacOS. I used to tag my photos using elements like ITPC. Category, ITPC. SupplementalCategories and ITPC.Keywords. I had the assumption that this kind of tags should be visible in the Categories browser.
Unfortunately it is not visible. Is there a way to show these structures? I tried to create a new Category and some mapping. I can not figure out, how to show a tree with my own values.
Is it possible to create a view on these elements? And if so, how can I organize this?
Re: use ITPC tags in the Category browser
In the Details section you can see many fields. If you need more fields that aren’t displayed by default then use the Info Panel to add predefined custom fields. The ones you mention are available from the drop down (Advanced)
