Update to 7.3.0.4453 killed to function to rotate using the preview mouse over
OGroeger
Post by OGroeger »
The mouse over shows the arrows to rotate but they have no effect.
Best regards
Olaf
Bildschirmfoto 2022-07-31 um 10.35.28.png (213.4 KiB) Viewed 2493 times
Re: Update to 7.3.0.4453 killed to function to rotate using the preview mouse over
I've noticed an oddity on these as well, sometimes they work sometimes they don't, there seems to be a delay as well in displaying the processing progress, in that nothing happens for several seconds and then the progress bar flashes up and disappears but then the rotated image appears shortly after.
OGroeger
Post by OGroeger »
Fixed in 7.3.1 4532.
(At least for me and i seem to be the one person that had this problem)
Thank you very much, Hert.
