Light Table Ratings Bar
rolandgifford
Post by rolandgifford »
Is it possible to remove options from the Light Table Ratings Bar
I'm only interested in the star ratings. If I open 8 images at once I can see all of the options I don't want but not the one that I do. Six appears fine but sometimes I want eight. Removing what for me is clutter would be good for all numbers of images if possible.
Re: Light Table Ratings Bar
Open an image in the Image Viewer (not Light Table).
There, exclude the bookmark from the Viewer's options
Then restart PSU
Open an image in the Light Table.
rolandgifford
I already had Show Bookmarks unticked
The only ones ticked are Load Full Size Images, Show Ratings and Show Recipe Indicator. I have tried turning off the third one but it comes back.
Restart PSU after changing the Viewer's options
rolandgifford
I did, following your instructions
As I said, Bookmarks were already turned off
rolandgifford
For clarity, the Light Table icons I'm not interested in are:
Quick Select
Stack
Full Screen
Loupe
Zoom
Dim Light
Reducing the size of icons would do what I want as I just want there to be space for the ratings when I'm looking at eight images
Removing any two would probably provide enough space
