Rating bar disappears when movin mouse over image
tumirnix
Post by tumirnix »
there seems to be a new "feature" or bug in the version 7.1.5.4366:
When a single image is enlarged the rating bar (with the 0 to 5 stars) disappears when the mouse (cursor) is moved over the image. It comes only back when clicking the "R" key or when moving over the lower part of the image (where the rating bar is located).
The same behavior I observed in the Light Box (Ctrl+Y).
Can someone else reproduce this?
Best regards
Martin
Re: Rating bar disappears when movin mouse over image
In the options of the Image Viewer (lower right) you can toggle what to see.
Click the pin icon to keep the bar visible.
tumirnix
Post by tumirnix »
Thanks for the hint. In fact the solution was a bit away: the pin on the lower left corner.
