The contextual menu don't display "Run Script from Repository" anymore. Why
"Run Script from Repository" - Where ?
Re: "Run Script from Repository" - Where ?
Possible reasons:
1. you disabled the Repository in the Preferences (Preferences -> Other Settings)
2. you were (temporarily) disconnected from the internet or some other kind of connectivity issue
3. you blocked PSU from connecting to the internet (firewall)
4. The Repository Server was temporarily unavailable
If 4 then it will eventually automatically return after a restart.
1. Preference : OK
2, Internet OK
3 & 4. repository service OK : I can see there the script.
On the second computer, it's the same.
Can you tell me if Google API key is mandatory to use the repository service using the contextual menu ?
2, Internet OK
hello,
it is the same here :
no "Run Script from Repository" in contextual menu
and no "Repository" parameter in the Preferences (Preferences -> Other Settings) !!
(no problem with firewall and connection)
i'm in PSU 6.7.2.4216 on Macintosh M1 and in 'FRENCH'
thanks for your help
[ external image ]
[ external image ]
- Capture d’écran 2022-06-03 à 18.20.08.jpg (576.8 KiB) Viewed 3145 times
@Gilles :
La version anglaise est plus explicite "Integrate Online repository" et ça correspond à "Intégrer un répertoire en ligne". Comme la case est cochée, c'est tout bon.
Reste à savoir si c'est lié à Google qui a changé ses règles d'accès en début du mois....
- Screenshot 2022-06-03 at 19.10.57.png (424.11 KiB) Viewed 3133 times
compris ...
j'ai testé avec diverses versions PSU v6 : idem
attendons le retour de Hert
understood ...
I tested with various PSU v6 versions : idem
let's wait for Hert's return
understood ...
After a PSU restart it should now be working again. The service had a problem which only sufficed on macOS but not on Windows.
The Repository Service is not using the Google API.Can you tell me if Google API key is mandatory to use the repository service using the contextual menu ?
thank you
everything is OK !!
Its all working as expected here with the latest version build 7.1.5.4353, all the repository links are present when web connected, and they disappear when web connection is lost.
It would be nice if Hert could build in a local cache for the repository items so that the most recently used are available when working at an event and no web connection!
Yes, it's working again.
Thank you for your intervention, Hert.
About feature request from G8DHE : +1
