does the script "change the temp folder" work under ps7 and portable?
mantras
Post by mantras »
Hi
does the script
WriteToRegistry('', 'SQLiteTempDir', 'D:\Temp"');
work under photo supreme 7 and does it work with portable version too?
I have found the script here in the forum viewtopic.php?t=23286
I have perfomered a short test ,using process hacker , and ps7 does it use the windows temp folder
can somebody confirm and test it with the portable version too?
thanks
Re: does the script "change the temp folder" work under ps7 and portable?
That registry tweak still exists in V7
mantras
Post by mantras »
Hert wrote: 30 Apr 22 17:17 That registry tweak still exists in V7
Hi
i have tried on the portable mode -portable , and it doesn't work
While setting the temp folder in SQLite still exists in SQLite, the SQLite team deprecated it and highly discourage the use of it.
How do you know it’s not working?
mantras
Post by mantras »
Hert wrote: 01 May 22 6:09 While setting the temp folder in SQLite still exists in SQLite, the SQLite team deprecated it and highly discourage the use of it.
Hi
i have used on windows process hacker and process explorer , on disk tab i can see writing and files
i have selected a bunch of files and use the share to another folder resezing
and ps7 created lots of temp files on the windows 10 temp folder
You are setting the SQLTempDir. That is the dir that SQLite uses and is not the same as the Windows Temp dir which is used to store temporary files.
The TEMP folder will always be the OS's TEMP folder. That is only configurable in the OS.
But...I agree that -portable should fix not only the appdata folder but also the temp folder. All you should need to configure is the -portable parameter
