Stacks and Adjustments possible bug V7
germie
Post by germie »
Hi All,
If I select an image that is part of a stack, go to Adjust, and hit "save recipe" that image is removed from the stack it was part of.
I am using 7.0.1.4264. Can anyone confirm this? Thanks!
Kind regards from Holland
Germ Wind
Re: Stacks and Adjustments possible bug V7
Thank you. I was able to reproduce that. Please update to build 4275 (from the Control Panel).
germie
Post by germie »
Man, you work FAST! Downloaded 4275 and problem solved.
Thanks Hert!
