JPEG Exports from DXO Photolab 5 reading odd DPI's in the Info View of PS
BlackrazorNZ
Post by BlackrazorNZ »
Hi there,
My workflow I'm trying is:
- Import RAW to Photo Supreme
- Open RAW in DxO Photolab 5 via that option.
- Process RAW in PL5, Save as JPG version to same folder, set at 300 dpi
- Refresh folder in Photo Supreme, and then auto-version via the Detect feature.
That workflow works really well. However, I've encountered a bug where PS on its Info tab shows some crazy high DPI (like, in the billions) despite the fact the file itself is showing as 300dpi when inspected elsewhere.
Any idea what's causing this? the DPI are showing correct in other images (not from PhotoLab).
Original RAW
Screenshot 2022-03-20 174407.jpg (18.24 KiB) Viewed 2789 times
JPG conversion showing funky DPI count.
Screenshot 2022-03-20 174450.jpg (18.13 KiB) Viewed 2789 times
Details tab of Windows file Properties showing correct DPI.
Screenshot 2022-03-20 174541.jpg (37.23 KiB) Viewed 2789 times
Re: JPEG Exports from DXO Photolab 5 reading odd DPI's in the Info View of PS
DPI is stored at different metadata levels and a tool updating the DPI is responsible to update all of these levels. The info panel shows you what is in XMP's tiff:XResolution field, displayed depending on XMP's tiff:ResolutionUnit field.
You can use right click on thumb -> Run script from repository -> Metadata -> Full Exif Dump
Can you copy/paste the result here (remove personal information if any)?
Tip: from your description it appears that DxO isn't updating the XMP resolution correctly. PSU can fix that for you by using right click -> Metadata -> Convert metadata to XMP. That will re-convert lower metadata levels to XMP, fixing discrepancies at metadata levels. This is especially helpful to fix metadata issues created by tools that update some, but not all, of the metadata levels.
Tip2: Also report this to DxO
BlackrazorNZ
Hert wrote: 20 Mar 22 7:44<snip>
<snip>
Thanks for the above feedback, much appreciated. Below is the EXIF dump, I only masked the GPS coordinates and the folder structure :)
Info=Intel byte order
eXtensible Metadata (XMP) Exists?=Yes
IFD0 Segment Available?=Yes
Camera Maker=Panasonic
Camera Model=DMC-GM5
Orientation=Normal
MinSampleValue=685568
MaxSampleValue=??.?_
XResolution=300.00
YResolution=300.00
PageName=
Resolution Unit=Inch
Software=DxO PhotoLab 5.1.4
Date Time=2022:03:21 18:24:59
YCbCrPositioning=Co-sited
Rating=0
RatingPercent=0
ExifOffset=438
0xC4A5 (50341)=PrintIM
Panasonic Title=
Panasonic Title2=
IFD1 Segment Available?=Yes
Compression=Jpeg
XResolution=72.00
YResolution=72.00
JPEGInterchangeFormat=14008
JPEGInterchangeFormatLength=20271
ExifIFD Segment Available?=Yes
Exposure Time=1/200 sec
F-Number=F1.7
ExposureProgram=Aperture priority
ISO=200
SensitivityType=1
ExifVersion=0230
Date Time Original=2022:03:21 18:20:35
Date Time Digitized=2022:03:21 18:20:35
0x9010 (36880)=+13:00
0x9011 (36881)=+00:00
ComponentsConfiguration=
CompressedBitsPerPixel=2
ExposureBiasValue=EV 0/100
MaxApertureValue=F1.5
Metering Mode=MultiSegment
LightSource=Unidentified
Flash=Off
Focal Length=15.00 mm
SubSecTimeOriginal=272
SubSecTimeDigitized=272
FlashPixVersion=0100
ColorSpace=sRGB
Exif Image Width=4592
Exif Image Length=3448
InteroperabilityOffset=13464
SensingMethod=One Chip Color Area
FileSource=
SceneType=
CustomRendered=Normal Process
Exposure Mode=Auto
WhiteBalance=Auto
DigitalZoomRatio=0
Focal Length in 35mm Film=30.00 mm
SceneCaptureType=Standard
GainControl=Low Gain Up
Contrast=Normal
Saturation=Normal
User Comment=
GPSIFD Segment Available?=Yes
Maker Notes Available?=Yes
Image Quality=RAW
FirmwareVersion=
White Balance=Auto
Focus Mode=Auto
Auto Focus Mode=1-Area
Image Stabilization=Off
Macro Mode=Off
Shooting Mode=Aperture Priority
Audio=No
0x0022 (34)=0
Flash Bias=0
Internal Serial Number=X041411090002
Panasonic Exif Version=0408
0x0027 (39)=0
Color Effect=Off
Time Since Power On=2 s, 930 ms
Burst Mode=Off
Sequence Number=0
Contrast=1
Noise Reduction=Standard
Self Timer=Off
0x002F (47)=1
Rotation=Horizontal (normal)
AF Assist Lamp=Disabled and Not Required
Color Mode=Normal
Baby Age=9999:99:99 00:00:00
Optical Zoom Mode=Standard
Conversion Lens=Off
Travel Day=65535
0x0037 (55)=257
0x0038 (56)=1
Contrast=0
World Time Location=Home
Text Stamp=Off
Program ISO=65535
Advanced Scene Type=1
Text Stamp=Off
Faces Detected=0
Saturation=0
Sharpness=0
0x0043 (67)=255
Color Temperature (Kelvin)=5800
Bracket Settings=No Bracket
White Balance Adjust AB=0
White Balance Adjust GM=0
Flash Curtain=n/a
Long Exposure Noise Reduction=Off
Panasonic Image Width=4592
Panasonic Image Height=3448
0x004D (77)=128/256,128/256
0x004E (78)=
0x004F (79)=0
Lens Type=LEICA DG SUMMILUX 15/F1.7
Lens Serial Number=04EIC207062N
Accessory Type=NO-ACCESSORY
Accessory Serial Number=0000000
0x0055 (85)=1
0x0058 (88)=
0x005E (94)=
0x005F (95)=
Lens Firmware Version=
0x0061 (97)=
0x0063 (99)=
Title=
Baby Name=
Location=
0x0068 (104)=0
Country=
0x006A (106)=0
State=
0x006C (108)=0
City=
0x006E (110)=0
Landmark=
Intelligent Resolution=Off
0x0071 (113)=
0x0072 (114)=0
0x0073 (115)=0
0x0074 (116)=0
0x0075 (117)=0
0x0076 (118)=0
Burst Speed=0
0x0078 (120)=0
Intelligent D-Range=Off
0x007A (122)=0
Clear Retouch=Off
0x007F (127)=0
City as stored by some models=
0x0081 (129)=
0x0082 (130)=
0x0083 (131)=
0x0084 (132)=
0x0085 (133)=
0x0087 (135)=65535
Photo Style=Standard or Custom
Shading Compensation=Off
0x008B (139)=0
Accelerometer Z=272
Accelerometer X=65532
Accelerometer Y=65521
Camera Orientation=Normal
Roll Angle=65531
Pitch Angle=65533
0x0092 (146)=0
Sweep Panorama Direction=Off
Sweep Parorama Field Of View=0
Timer Recording=Off
0x0097 (151)=0
0x0099 (153)=0
0x009A (154)=1
0x009B (155)=100/100
Internal ND Filter=0
HDR=Off
Shutter Type=Hybrid
0x00A0 (160)=X
0x00A1 (161)=0
Clear Retouch Value=0
0x00A6 (166)=0
0x00A7 (167)=
0x00A8 (168)=0
0x00A9 (169)=0
Touch AE=Off
0x00AC (172)=0
0x00AD (173)=0,0
0x00AF (175)=2022:03:21 05:20:35
0x00B0 (176)=50000
0x00B3 (179)=1
0x00B4 (180)=1
0x00B5 (181)=0/100
0x00B6 (182)=
0x00B7 (183)=0
0x00B8 (184)=
0x00B9 (185)=0
0x2003 (8195)=
Maker Note Version=0148
Scene Mode=Off
0x8002 (32770)=1
0x8003 (32771)=1
White Balance Red Level=2764
White Balance Green Level=1024
White Balance Blue Level=1624
Flash Fired=No
Text Stamp=Off
Text Stamp=Off
aux:Lens=LEICA DG SUMMILUX 15/F1.7
exif:DateTimeOriginal=2022-03-21T18:20:35.272Z
tiff:Orientation=Normal
xmp:ModifyDate=2022-03-21T18:24:59+13:00
xmp:MetadataDate=2022-03-21T18:24:59+13:00
xmp:CreatorTool=DxO PhotoLab 5.1.4
xmp:Rating=no star
xmp:RatingPercent=0
BlackrazorNZ
<snip>
I tried the above 'Convert metadata to XMP' tip, and unfortunately it didn't fix the issue. It did, however, remove the lens data, for some reason :(
Screenshot 2022-03-21 181133.jpg (14.44 KiB) Viewed 2748 times
Looking at the XMP tiff:Xresolution field, I can see it has very odd numbers stored. Unfortunately, they are not editable directly, unlike many of the other fields.
Screenshot 2022-03-21 181345.jpg (17.29 KiB) Viewed 2746 times
Thank you for the additional info.
Can you send a copy of this particular image to support@idimager.com
tia
BlackrazorNZ
Hert wrote: 21 Mar 22 8:15Thank you for the additional info.
Have done so, thanks.
Thank you for the sample file.
I can now tell you what is in that box. It reads:
9830400/32768dpi
If you do the math then that comes down to 300 pixels per inch. It's untypical for the resolution to be written in such fraction, but that is still a valid way of writing a resolution.
PSU should have done the math here and show it on-screen as 300 instead of the fraction.
BlackrazorNZ
Ah OK cool, well hopefully will be addressed in a future update :)
