Filtering by Count of Labels Assigned
BlackrazorNZ
Post by BlackrazorNZ »
Hi there,
I have searched and searched, and I'm probably blind, but:
How can you filter or search to show all items in an applicable category that have a certain number/count of labels assigned?
I'm planning on using it for 2 scenarios :
- Create a favourite that shows all photos with no labels assigned at all, so that I know this is my 'to do list' for images that need labels, and
- Create a favourite that shows all photos that have been assigned to a parent category, but not to a subcategory (so a Label count of 1, but not any with a Label count of either zero, or >=2). I can use this to create a list of images that i've assigned to a broad/parent category, but need refinement into a subcategory still.
Thanks for any assistance.
Re: Filtering by Count of Labels Assigned
A warm welcome to the forum.
1. To see all images in a applicable category you can click the counter behind the category name
2. To get images without assigned labels:
a. click the filter icon (above the thumbs)
b. from the Labels drop down, select "With no labels"
tip 1: you can also use: States -> Not Catalog Labeled
tip 2: to get all images with a specific number of labels you can click the FILTER button in the filter bar -> From Repository -> Filter with exactly n labels. Note that filter scripts cannot be part of a favorite.
