Version Cascade not working?
agk7
Post by agk7 »
Hi all,
I seem to be having an issue with Cascading colour and star ratings across versions. I've imported NEF & JPG and created versions as part of this. Rate / Colour labelled all of my JPG's and now looking to cascade this to NEF's but the NEF files are not being updated? Any clues? Thanks in advance.
Andrew.
Andrew
Albury, Australia
PSu 6 Win10
agk7
Re: Version Cascade not working?
Post by agk7 »
A little update with some more testing, when I "Select All" and cascade I seem to get some Colour & Star ratings cascading down but not all?
Andrew
Albury, Australia
PSu 6 Win10
sanphotgn
Post by sanphotgn »
I recently reported on Mantis something similar: Values and macros not being applied to all, only visible or partially visible thumbs.
https://mantis.idimager.com/view.php?id=3485
agk7
Post by agk7 »
Thanks Sanphotgn, I'm not a member over there, was there a solution to the problem?
Andrew
Albury, Australia
PSu 6 Win10
sanphotgn
Post by sanphotgn »
agk7 wrote: 20 Jan 22 9:36 Thanks Sanphotgn, I'm not a member over there, was there a solution to the problem?
Not yet. When I first reported the issue, I thought I had found a workaround: slowly scroll through the images before applying the value or macro. Yesterday, that didn't work (but now I am wondering if "Select All, scroll" compared with "scroll, Select All" makes a difference; or it isn't related). Right now: I have created a few filters and use them after each update to identify the images that haven't been updated.
agk7
Post by agk7 »
Righto, it's very frustrating and is now really limiting the effectiveness of PSU for me. I seem to be getting all sorts of erratic behaviour with my Versions, some losing the relationship, not cascading. very frustrating, thanks Samphotgn. hopefully I can find a cause and fix somewhere...
Andrew
Albury, Australia
PSu 6 Win10
You don't mention what version you are using. Always make sure to use the latest build:
https://www.idimager.com/what-s-new-in-photo-supreme-v6
