Moving files within PSU very slow
pattcz
Post by pattcz »
When i move photos within PSU from folder to folder it so slow. 20 images took almost three minutes. When i try move images in file exlorer and reenter images to PSU it was like 30 seconds with delays on my clicks and PSU make new thumbnails.
Anybody experince that or is that normal behavior ?
Re: Moving files within PSU very slow
I just did this for 20 images that I drag from a folder to another folder in PSU. It takes 2 seconds.
FYI; when you move files then PSU uses the OS routines for the actual file moving, that same as what the file explorer from in the OS uses.
You may want to check that you have excluded the Catalog folder from any virus scanner that you have installed, including the one integrated in your OS (if any).
pattcz
Post by pattcz »
i make some intensive tests and figure out that after some huge work (like adding hundreds of images , then label them and thumbnail generation) it is good to restart PSU , then moving between folders in PSU is somewhat fast.
excluding antivirus help a little ,i monitor CPU usage and RAM usage and guess i need upgrade , when moving files it jumps to 60% cpu and 1,7 gb of ram (have i5-7500 3,4ghz , 16 gb ram)
