Changing lens info, focal length, f-number
fabrizio.giudici
Post by fabrizio.giudici »
Hello. I have some photos with missing EXIF info due to a lens without chip, so I have to manually set some things. From the "Details" page / Technical I'm able to insert a custom lens information, but f-number is stuck to "unknown" and focal length to 0.0 mm, without offering me an editable field.
How am I supposed to fix this? Thanks.
Photo Supreme + Capture One
http://stoppingdown.net
Re: Changing lens info, focal length, f-number
I have just created a script for this:
Edit Lens Info.png (296.16 KiB) Viewed 2334 times
Does that help?
fabrizio.giudici
Thanks - I'll try as soon as I fix a mistake I've just done (see my next post). Actually Photo Supreme is so full of stuff I'm taking a long time to "discover" everything...
fabrizio.giudici
I tried it with photos not affected by the mistake I was referring to, and it's ok.
Ruhell
Post by Ruhell »
Excellent work Hert! I've been waiting for this a long time.
The next would be a possibility to save different lenses and an easy (read fast/quick) way to recall the different lenses.
Is it possible to save/make a shortcut/icon without having to rightclick and then to go down two levels to select "edit lens information"?
