why is not the field (sofware) not available custom field?
mantras
Post by mantras »
Hi
i'm tring to add a new custom field with field name software , software used to edit the image
in the thumbnails i have found it %exif:Software{encode=html}
i need it to find very quickly image edited with different software
is there a way to have a custom field %exif:Software ?
thanks
Re: why is not the field (sofware) not available custom field?
As recommended to you before: use XMP properties instead of Exif properties where possible!
So use %xmp:tiff:software
To add it as a Custom Field:
mantras
Post by mantras »
Hert wrote: 08 Aug 21 11:10
Hi Hert
yes i get it , i use always Xmp properties
but in this case software is under tiff , it's a file format (like jpg or psd ) isn't it ?
thanks
Tiff is a file format but also a tag system (the t stands for Tagged). The software tag is defined in XMP standard as part of the tiff schema.
mantras
Post by mantras »
Hert wrote: 08 Aug 21 15:26 Tiff is a file format but also a tag system (the t stands for Tagged). The software tag is defined in XMP standard as part of the tiff schema.
hi Hert
thanks
Larry56
Post by Larry56 »
Hert,
I'm curious why use xmp vs exif?
In the past I've used exif which was a pain in the neck to edit so I stopped doing it. xmp seems much easier with not having to use special software to edit exif. As I recall some programs such as Capture One(?) wrote their name into exif and some don't (ON1).
I have found one oddity perhaps you can explain. I have some photos taken with Sony A7iii and the tiff:software custom field I just added shows Software: ILCE-7M3 v3.10. Because Sony writes to that xmp field thinking it's software too?
edit: Just noticed that Sony RX100 does the same thing.
Larry56 wrote: 12 Aug 21 0:38I'm curious why use xmp vs exif?
Performance. PSU is XMP driven.
%exif is read from the physical file (meaning the file needs to be opened, the metadata read before the value can be displayed)
%xmp is read from the database
The camera write its software version (firmware is the software of a camera) in the software tag. That is perfectly fine.
Larry56
Post by Larry56 »
Thank you for that information.
