can you pre-select a checkbox when scripting using AskCustom?
mjbiggs
Post by mjbiggs »
Hello
Referring to the example script 'Say and Ask.psc' from the script repository, and in particular the 'AskCustomChecked' example, is it possible to pre-select one of the checkbox items, so it appears already checked?
following code from 'Say and Ask.psc':
procedure AskCustomChecked;
var
  ASl: TTntStringList;
  AChecked: Boolean;
  ARes: Integer;
begin
  AChecked := True;
  ASl := TTntStringList.Create;
  ASl.Add('?john');
  ASl.Add('?jane');
  ASl.Add('?baby');
  ASl.Add('?janie');
  ASl.Add('?johnny');
  ARes := AskCustom(
            'select option',
            'sub text',
            '',   // 'info text'
            '',   // 'check this'
            AChecked,
            ASl
  if ARes <> -1 then
  begin
    Say(ASl.Text);
  end;
  ASl.Free;
end;
AskCustomChecked;
mjbiggs
Re: can you pre-select a checkbox when scripting using AskCustom?
Post by mjbiggs »
...further to my last...
How do you display radio buttons instead of checkboxes, and can you pre-select one of them?
thanks again
AskCustom in the scripter doesn't allow default checks, nor radio buttons.
You can always construct your own form if needed.
mjbiggs
Post by mjbiggs »
Ok, that's great. Will investigate forms.
Many thanks for your reply.
