TEST.JPG at root level showed up again
mballe
Post by mballe »
So I have previously had a TEST.JPG folder/file show up at the root level. When I delete it, it comes back later.
This time I am certain that I haven't made anything named TEST.JPG. Last time I found the item in the postgresql server, and managed to delete it.
It must be something that PSU does under a certain condition, I guess.
Re: TEST.JPG at root level showed up again
Is that file still there after a restart of PSU? I'm wondering if it's a visual thing only or if that file exists in the catalog
mballe
Post by mballe »
Last time I found TEST.JPG in a row in the Postgres database using pgadmin. So it is not just a visual thing.
I have added a screen shot showing my sql query and the TEST.JPG showing in the table
PSU Screenshot.png (416.95 KiB) Viewed 2640 times
Very odd and I cannot explain how it ends up in the database. If you find out at what point the test.jpg is added then please let me know. Maybe when a new file path is added to the catalog? Or when a new volume is first added to the catalog?
tia
mballe
Post by mballe »
I am not sure what could have caused it. It just suddenly started showing. I have added files, but no new volume.
I have now deleted that row, and everything is fine again.
