When you have PSU setup to always use xmp sidecar, files shared as copy to file are saved with a xmp sidecar too.
I would have expected shared files to have metadata embedded, or at least have a choice to do too for shared files.
Files shared with xmp sidecar
Re: Files shared with xmp sidecar
While i don't use this functionality myself. I think this behaviour is as expected. You set PSU to create xmp for each managed file and when you create a copy to share, that is managed too. As a result it will have an xmp sidecar file.
If you'd like to see new functions, it's best to log a feature request via mantis, the ticket tracker for PSU (https://mantis.idimager.com/login_page.php). Other users can vote for your reqest to raise priority.
I am talking about the case where you export a file by using the copy to folder share profile. The exported file is not managed and should have metadata included in the file.
