Move to folder during rename
mballe
Post by mballe »
I thought it would be possible to move a file to a subfolder as part of renaming it, but I have not yet gotten it to work.
I tried using this simple rule to move a file into a subfolder named after the file extension.
%FileExtension{pathdelimiter=y}%FileName.%FileExtension
What am I doing wrong?
Re: Move to folder during rename
mballe wrote: 15 Mar 21 22:49%FileExtension{pathdelimiter=y}%FileName.%FileExtension
You're missing the file path. try this:
%FilePath{pathdelimiter=y}%FileExtension{pathdelimiter=y}%FileName.%FileExtension
mballe
Post by mballe »
Thanks. That worked.
mballe
Renaming a file into a subfolder forgets to move xmp sidecar file
Post by mballe »
If you rename a file, and the rename rule moves the file into a subfolder, the associated xmp sidecar files are not moved with the file.
One example is this simple rule:
Re: Renaming a file into a subfolder forgets to move xmp sidecar file
Works fine here
mballe
Post by mballe »
Not for files that would normally have xmp embedded, like JPG and DNG
Ah yes, that will be fixed in the next build
mballe
Post by mballe »
Thanks Hert. Works perfect with latest build.
mballe
Post by mballe »
Except for one for problem. For versioned Raw(DNG)+JPG+xmp, only the Raw and xmp is moved to the subfolder.
The rename feature works on selected files.
If you want to rename all versioned files then:
1. Select your version set(s)
2. Right click on a version set
3. Select Show More -> From This Version Set
4. Select all files
5. Start the rename
