Exportation
Henri T.
Exportation
Post by Henri T. »
Bonjour,
A partir de Photo Supreme, comment exporter un fichier RAW dans mon logiciel de dématriçage (Capture One) ?
Merci
Re: Exportation
A warm welcome to the forum.
You can defined CaptureOne as an external application in Preferences > Other Settings -> External Applications
Once CaptureOne is defined as an external application, then an icon appears in the upper right corner of the application. Then select one or more RAW files and click the CaptureOne button open the selected file(s) in CaptureOne
Henri T.
Re: Exportation
Post by Henri T. »
Merci beaucoup ! c'est fait et ça marche !
