Configurable default action for folder names
Many editors make use of additional folders with specific names to hold editor/version information on changes made to images.
When Importing or Verifying file structures these folders usually have to be individually manually altered for some other default (No Action / Ignore).
Would it be possible to add to Preferences a list of such folder names with the preferred default rather than the standard default action ?
Typically I have two that frequently get scanned and need to be manually altered before Verifying etc.;
Paint Shop Pro - "Corel Auto-Preserve"
Nikon NX-D = "NKSC-PARAM"
I have created a Feature request on Mantis for this https://mantis.idimager.com/view.php?id=3437
Ralf
Re: Configurable default action for folder names
Post by Ralf »
that would be really great, that would save a lot of clicks
+1
Ralf
(Excuse my english)
germie
Post by germie »
That would life al lot easier!
+1
HCS
Post by HCS »
germie wrote: 09 Feb 22 12:29 That would life al lot easier!
+1
Please login to Mantis and +1 there. Hert is looking at those votes to determine whether to include the request in PSU.
germie
Post by germie »
I tried, but I have trouble logging in to mantis or even create a new account. It promises to send emails, but they never arrive in my mailbox. What to do?
germie
Post by germie »
Created a new mantis account using new email address and added +1 to the post in Mantis.
Germ
Excellent news! Not sure what criteria Hert has for new features but maybe we are getting close :-)
Just realised its still under Version 5 heading, but hopefully Hert does bring these things forward!
I see we are still gathering +1's for this feature now up to 6 requests for the feature :-) Please ?
Is this not implemented in V7?
Not that I can see ?
Save attached file in your AppData folder to have the default action for a folder named NKSC-PARAM to be "No Action".
VerificationUserDefaultActionsConfiguration.txt
(12 Bytes) Downloaded 397 times
If you don't know what your AppData folder is then run this little script in the Tools -> Scripter:
Say(DefaultAppDataDir);
Yea! Thank you Hert :-)
Mind you nearly caught me as the folder name was NKSC_PARAM not NKSC-PARAM but that was my mistake in the first post!
germie
Post by germie »
WOW thanks Hert! Icing on the cake!
Germ Wind
Great.
BTW, the name can be masked; e.g. *NKSC*.* to set the default action for any file/folder that contains the NKSC string
MarqsM
Post by MarqsM »
Thank you Hert, I can confirm it is working.
It is possible to add some other folders in the TXT file, in the next lines, and they are working too (e.g. "CaptureOne", "_Rejected" for FastRawViewer etc.).
I would like just to remark, that it is required to update to the latest version 4275 (no update trigger from the hamburger menu, I had to download from the User Control Panel). On the previous version 4268 it didn't work.
