How to use Photo Supreme with more than one HDD
Chris47
Post by Chris47 »
How do you use Photo Supreme with more than one HDD?
Photo Supreme is only displaying my Mac HD and the folders and files on there. However, I have an external HDD (WD My Passport for Mac) where I wish to store the files created by my processing app (Affinity Photo). These are large and are using up my internal hard disk at quite a rapid rate, so whilst I want to keep the RAW and exported JPEG files on the internal HDD, the Affinity files I want to store on the external drive. However, Photo Supreme does not recognise or display any storage plugged in through the USB ports.
I assume there is a way to access more than one HDD as I cannot be the only person that needs or has to store images on more than one HDD?
Chris
Re: How to use Photo Supreme with more than one HDD
Photo Supreme shows folders that are imported.
Once you import some images from that external HDD, it will also appear in Photo Supreme. Use Import Folder from the upper left hamburger menu to import an existing folder from the external drive.
Chris47
Post by Chris47 »
All sorted and working now. Thanks for the help.
Chris
