Is there a way to have Preferences>File Handling>Other File Extensions consistent from one catalog to another, without having to re-enter the data each time?
I create a catalog for each job/project (as an illustrator/designer) and have ended up with a lot of catalogs. Each time I have to enter things like .afdesign, .indd, and now that I've started using Clip Studio Paint, .clip. There are enough that I always end up forgetting something.
Along the same lines, I'd really like to have my View>Style settings the same across all catalogs.
Thanks for any help with this.
Mark
[update Hert; changed title]
Consistent Preferences & View settings
Re: Consistent File Handling & View settings
You can use this script;
https://repository.idimager.com/openres ... 43ACB09937
Re: Consistent Preferences & View settings
Thanks, Hert.
When running the script, I get this error: "~Desktop/options.psu Not Found"
Am I missing a file I need somewhere?
Mark
Mark
Please try to download the script again
That seems to have done it, Hert. Many thanks!
Mark
Mark
