Start with empty catalog
dino
Post by dino »
I appreciate very much the default labels ... in particular the default country labels with their little flag icons ... is it possible to set up PSU with a brand new empty catalog ... please advice how to proceed (sorry for this newbie question)
i am on a Win 10 desk top with SSD as c: partition,
PSU (V5) and catalog is on FD d: partition,
pictures are mainly on FD e: and USB portable FD
Thanks in advance
dino
Re: Start with empty catalog
You can delete the existing sample labels. Select the all (Ctrl+click on Windows or Cmd+click on macOS) and right click on a selected label and select "Delete Selected"
dino
Post by dino »
Thank you Hert ... my problem are not the existing default entries but the missing one which i deleted by mistake ... is it possible to have a new empty catalog with default labels?
Select Catalog -> Create a New Catalog
dino
Post by dino »
In my new *empty* catalog i found in 'Europe' 13 different country labels only and e. g. in 'Asia' no country at all ... how can i get more default countries?
The labels in the "empty" catalog are there as samples. If you need more countries then you can always create them.
