Remote Access
Paul Harris
Remote Access
Post by Paul Harris »
I have been a Single User, Local Machine Installed version user for many years, since original IDImager days. Forgive me if this is embarrassingly obvious to many of you, but because of the realm I have operated in all these years, I HAVE to ask.
I may be looking at opening my catalog, if only for viewing, with certain remote family members. In order to have multiple access, I presume I would have to migrate to the Server Ediition, but I have always been under the impression that it would only work on a LAN. What options exist, and has there ever been any talk of a cloud based version of Photo Supreme?
Paul
Re: Remote Access
Hi Paul, a web module is not available. Your best option is to sync a portfolio that you'd like to share with Flickr and share that with your family.
Paul Harris
Re: Remote Access
Thanks, Hert.
Re: Remote Access
You can always VNC into the machine from the remote location perhaps ?
https://www.realvnc.com/
Paul Harris
Re: Remote Access
Thanks, Geoff. I'll look into this.
Paul
Username
Re: Remote Access
Post by Username »
In either way you stay at single user or move to the server based PSu.
Remember to never ever open up ports in your router for direct access to your lan and computers on the inside.
Either set up a VPN server or check out if your router comes with it built in.
The VPN into your network and from there you can connect to your workstation.
PSO 6 on Windows Server 2022
- I'm the user
