scripting contribution
wphx
Post by wphx »
My work flow involves editing some jpeg & some raw. I make a shortlist of jpegs I want to focus on. I also want to be able to quickly select the corresponding raw files (where they exist) to put into a separate collection
Through working with online scripts in the repository (and marginal knowledge of pascal) I've created the script below. It currently is coded to recognise .rw2 files but can be adapted easily enough.
I've been fumbling around and it seems to work according my intention. I would like to be able to sort on photo date - that may come later unless someone can guide me on this.
There were a few odd things I couldn't get past (so created a new instance of ADs to delete idTempList at end of script)
I'm happy if anyone wants to tidy this up.
kind regards
anyhow:
var
  i: Integer;
  RawFile: WideString;
  RawExt: WideString;
  ADs: TDBXOMClientDataSet;
  AGUID: String;
  AItems: TCatalogItems;
begin
  if Selected.Count = 0 then
  begin
    Say('No image selected');
    exit;
  end;
  AGUID :='wphFB798C977A734F4FACDF1FF204676A87';
  ADs := Catalog.NewDataSet;
  ADs.CommandText := 'delete from idTempList where ClassGUID=''' + AGUID + '''';
  ADs.Run;
  RawExt := '.rw2';
  for i := 0 to Selected.Count - 1 do
  begin
    If CompareText(ExtractFileExt(Selected.Items.FileName),RawExt)<>0 Then
    Begin
      RawFile := ChangeFileExt(Selected.Items.FileName,RawExt);
      If WideFileExists(RawFile) Then
      Begin
        ADs.CommandText := 'insert into idTempList (ClassGUID, GUID) ' +
                           'select ''' + AGUID + ''', idCatalogItem.GUID ' +
                           'from idCatalogItem inner join idFilePath ' +
                           'on idCatalogItem.PathGUID = idFilePath.GUID ' +
                           'where (idCatalogItem.FileName = ''' + ExtractFileName(RawFile) + ''') ' +
                           ' and (idFilePath.FilePath = ''' + ExtractFilePath(RawFile) + ''') ' +
        //CopyTextToClipboard(ADs.CommandText);
        ADs.Run;
      end;
    end;
  end;
  ADs.CommandText := 'select ' + Catalog.FullColumnList('v.') + ' ' +
                     'from v_CatalogItem v, idTempList t ' +
                     'where t.ClassGUID = ''' + AGUID + ''' ' +
                     'and v.GUID = t.GUID ' +
                     'union all ' +
                     'from v_CatalogItemVersion v, idTempList t ' +
                     'order by FullFileName ' +
  ADs.OpenSet;
  AItems := TCatalogItems.Create(TCatalogItem, '');
  AItems.Name := RawExt + ' from sel.';
  AItems.AddDataSet (ADs, True);
  PublicBroadCast(nil, 'OpenNewTab', nil);
  PublicBroadcastObject(nil, 'ShowImageResults', AItems, nil, nil);
  AItems.Free;
  ADs.CloseSet;
  Catalog.FreeDataSet (ADs);
  ADs.Run;
  Say ('Done. Found ' + RawExt + ' files are placed in a new Tab');
end;
Edit Hert; reformatted and placed in a code block
Re: scripting contribution
Here's a cleaned up version.
Important is to use PublicCatalog and not Catalog (which was used in old scripts). The Catalog object variable is still available for backward compatibility only.
Another change was using the "Wide" versions like WideExtractFileName instead of ExtractFileName. The first will also work with special characters (like greek file names) where the latter would fail.
Furthermore I think your script is nice.
const
  cGUID   = 'wphFB798C977A734F4FACDF1FF204676A87';
  cRawExt = '.rw2';
var
  i: Integer;
begin
  begin
    exit;
  end;
  ADs := PublicCatalog.NewDataSet;
  try
    ADs.CommandText := 'delete from idTempList where ClassGUID=''' + cGUID + '''';
    ADs.Run;
  finally
    PublicCatalog.FreeDataSet(ADs);
  end;
  begin
    if not WideSameText(WideExtractFileExt(Selected.Items[i].FileName), cRawExt) then
    begin
      RawFile := WideChangeFileExt(Selected.Items[i].FileName, cRawExt);
      if WideFileExists(RawFile) then
      Begin
        try
                             '  select ''' + cGUID + ''', idCatalogItem.GUID ' +
                             '  from   idCatalogItem ' +
                             '  inner  join idFilePath on idCatalogItem.PathGUID = idFilePath.GUID ' +
                             '  where  (idCatalogItem.FileName = ''' + WideExtractFileName(RawFile) + ''') ' +
                             '  and    (idFilePath.FilePath = ''' + WideExtractFilePath(RawFile) + ''') ' +
          ADs.Run;
        finally
        end;
      end;
    end;
  end;
  try
    ADs.CommandText := 'select ' + PublicCatalog.FullColumnList('v.') + ' ' +
                       'where  t.ClassGUID = ''' + cGUID + ''' ' +
                       'union all ' +
    ADs.OpenSet;
    try
      AItems.Name := cRawExt + ' from sel.';
    finally
      AItems.Free;
    end;
    ADs.CloseSet;
  finally
    PublicCatalog.FreeDataSet (ADs);
  end;
  try
    ADs.Run;
  finally
  end;
  Say ('Done. Found ' + cRawExt + ' files are placed in a new Tab');
end;
wphx
Post by wphx »
Brilliant - the new code is absolutely clear - thanks - and your mod.s have helped me a lot.
wphx
Post by wphx »
oh ... the line 'widesametext(...' needs to read: 'not widesametext(...' - without the not it looks as though it works as it is picking up raw files in the selection, however it needs to pick up the *non* raw files in the selection and then test for existing raw files corresponding to the non raw file (for me at least - I always shoot jpg + raw when using raw).
Thanks again for the code revision
I fixed the "not WideSameText" in my version above
