Division by zero on Upgrade from v4 to v5
flaviocu
Post by flaviocu »
Hello
I just installed V5 over my V4. When starting up, after a second I get a division by Zero error. Now the database can no longer be openend in v4 (newer Version, I pressed OK once) and also not in V5 (Division by Zero Error). Ofcourse I failed to make a backup. Any ideas on how to solve this?
Thank you for you help
Re: Division by zero on Upgrade from v4 to v5
Can you send me a copy of the database? Best to use your favorite cloud storage (dropbox/googleDrive/WeTransfer/...) and send me a link. Only the catalog database is needed, no need for the thumbs database.
flaviocu
Post by flaviocu »
sent a link to support@
Check your email. I get the error that the password is incorrect
