delete default information in basic information pop up
julienhgr
Post by julienhgr »
I use a second screen to visualise my photos. But i use it in portrait mode.
In full-screen mode, when you press 'i' to show the basic information, the 'pop up' is so big in portrait mode because this 'pop up' screen is in portrait mode too.
How to delete default information in this pop up ? I would like to delete all information exept ,name, and description.
and i would like chose the size of this pop up to put it in landscape mode.
Do you if it's possible to do that ?
Thank you so much
Julien
Re: delete default information in basic information pop up
If you have your monitor in portrait mode then that means that you have a lot of vertical space. The Info Panel is also vertical. You can add information to the Info Panel but you can not remove the fixed fields. The blue frame here are the fixed fields. The red ones are the "custom fields".
Also watch https://www.youtube.com/watch?v=H4TpHOcD4vU&
julienhgr
Post by julienhgr »
Thank you hert for your answer about that.
But i will show you my problem with this pop up.
Exemple full screen.png (536.4 KiB) Viewed 1695 times
As you see it's so unconfortable in portrait mode in full screen.
thank you for your help.
Julien
