dynamic search - map to correct physical folder
angelanthony
Post by angelanthony »
so recently i experienced the following
ive mapped and imported a folder along with assets from a server located on my network
everything was fine i was able to tag my images . i usually verify the folder from time to time as
some times the assets change and i want to update photosupreme with the new assets
what ive noticed in the dynamic search the folder i originally mapped to was
\\desk1000345\pics\
when i verified this folder above i noticed photosupreme also created another folder in the dynamic search area
\\desk1000345\pics\ [CE79-12E4]
now interestingly enough ive noticed in one of the folders thats located on
\\desk1000345\pics\jane_doe - the folder exists but photos and photo count are gone in this folder
however when i goto the folder below in dynamic search the actual photos and count display
\\desk1000345\pics\jane_doe [CE79-12E4]
im suspecting photosupreme is hardcoding the path and using an identifying drive id or something
my question is . is this normal and also do i have to start all over and reimport all the folders and photos underneath \\desk1000345\pics\ [CE79-12E4]
i have well over 1.5 million images and it takes months to get everything imported into photosupreme .
any info and or suggestion will greatly be appreciated
Re: dynamic search - map to correct physical folder
Post by jstartin »
Yes it is normal, and no you don't have to reimport. See pages 8 & 9 of the Folder and File Management Quick Manual.
angelanthony
ok so im posting screen grabs so you can get a better understanding
in the first 2 screenshots you will see the in the dynamic search the folder i originally mapped to was
\\desk1000354\XESDAM_01\
the screen shot also shows that ebt_0405 doesnt have any photos in the folders
now when you look at the last 2 screenshots you will see in the dynamic search
when i scroll down to the folder
\\desk1000354\XESDAM_01\[CE79-12E4]
the screen shot also shows that ebt_0405 shows all the photos
this is all started when i verified a folder that was on \\desk1000354\XESDAM_01\ and then all of a sudden
this popped up in photo supreme \\desk1000354\XESDAM_01\[CE79-12E4]
now my question is whats going on and why is this happening . and do i have to reimport all the folders and assets into \\desk1000354\XESDAM_01\[CE79-12E4]
