HTML web galleries?
syncrasy
HTML web galleries?
Post by syncrasy »
The last time I evaluated PSu (in 2014), it did not include a feature to generate customizable HTML Web galleries. Is this still the case?
(I am considering migrating from Media Pro, which has this feature.)
Re: HTML web galleries?
These days people tend to use photo sharing services to share photos online. Flickr, ZenFolio, and SmugMug are examples of such excellent services. These services also allow you to control access to your online albums: private, public, only friends, or even link sharing (someone with a link can access the album). Photo Supreme provides features to share to these aforementioned photo sharing services.
Apart from that you can also export to a folder (which you can then upload) or use the FTP sharing feature. Both options allows you to configure the output files for size, watermarking etc.
You could then upload those to a personal website and run a service there that is able to publish photos that are available in folders on your server.
Sorry to have to disappoint you.
Features to generate HTML galleries was removed about a decade ago because it was hardly being used anymore.
syncrasy
Post by syncrasy »
Thanks, Hert. I figured the answer was still "no" but I thought I would ask. (Yes, I know about Zenfolio, etc., but I am already paying for my own web hosting service since I already design my own website and don't wish to pay for a service I don't need. That might change in the future, though.)
I do think it is unfortunate that PSu no longer supports this; as Hert says its precursor IDI did (a decade ago, has it been so long?).
Photosharing sites are great and I am using Zenfolio myself, but if you work at an institution and want to set up galleries as part of an institutional site maintaining a private web service on the side does not seem optimal. That said, as Hert points out, institutional sites often can accommodate you via FTP. In practice it unfortunately requires quite a bit more tweaking and is much less efficient that keeping things as easily in sync as with photosharring sites.
You could file a feature request in Mantis, but from what Hert writes, it sounds like there is only a remote chance of success this will again be implemented...
Post by snowman1 »
I'm pretty sure you will be able to find bits of freeware that can take a folder of images and create a page for you, though finding one that does it just the way you like may be harder.
Post by jstartin »
snowman1 wrote: 10 Sep 18 15:23 I'm pretty sure you will be able to find bits of freeware that can take a folder of images and create a page for you, though finding one that does it just the way you like may be harder.
It is noticeable, if my quick Google search can be trusted, that there are many web gallery applications out there that have not been updated for a few years, rather supporting Hert's contention that demand is much less now that it used to be.
syncrasy
Post by syncrasy »
Just so you understand what I'm talking about...
My Media Pro HTML templates are integrated into the program and rely on the catalog's fields and annotations, including custom fields and their contents, to create both index and media HTML pages. A similar template would have to be integrated within PSu for the HTML generation process to retrieve and insert PSu's annotation content for each image/page. I'm not aware of any third party code that could do this, free or otherwise.
syncrasy
Post by syncrasy »
jstartin wrote: 10 Sep 18 20:27 It is noticeable, if my quick Google search can be trusted, that there are many web gallery applications out there that have not been updated for a few years, rather supporting Hert's contention that demand is much less now that it used to be.
That might be true, but I know of at least four major DAM or DAM-like programs that have a Web gallery generation feature: Lightroom, FotoStation, Photo Mechanic, and Capture One. (Not all are equal in quality.) I won't pursue this with Hert since he has made his decision. When Media Pro no longer runs on my Mac, I'll likely choose one of those other programs to create my galleries.
syncrasy wrote: 11 Sep 18 2:56Just so you understand what I'm talking about...
Photo Supreme is all about open data. What you put in, you can get out. Unlike some other DAM tools, your data is never stored proprietary. With Photo Supreme, your data is written to your metadata using the industry standard XMP format. This includes your custom fields data, your portfolio collections, catalog label assignments, geo data, and of course image details. Your data is YOUR data.
Bottom line: PSU doesn’t lock you in by hijacking your data and so you don’t need PSU to generate HTML pages that make use of custom fields that are defined and written with PSU.
Having said this; any (HTML generator or other) product out there that supports reading advanced XMP will be able to read your custom fields from the metadata. It’s a matter of finding the right tool. And a dedicated generator will likely provide much cooler designs.
touriga
Post by touriga »
I see this thread is from 2018, however I wondered if anything has changed since then? I am interested in your comment Hert about the original IDI feature not being used very widely.
Maybe the demand for this has changed? Ten years ago I did not need the feature. I thought it was a nice to have, but at that time the use of the cloud as a platform for non-professional photograph sharing was still in its infancy. I think the predominant desire was to keep one's documents and photos under your own control.
That has changed hugely in the last 10 years, where the concerns about the cloud have reversed completely. Now we realise that our data is actually more secure and safer on the cloud than on our own equipment.
I would now like a no effort solution that at the click of a button in Photo Supreme that allows me to publish collections defined in the Catalogue. I would like, in PS, the ability to add industry-standard metadata defining access control per photo or per Catalogue "folder".
touriga
Post by touriga »
... and as a P.S. If I am to use a third party service is there one (or more) that really stand out as integrating with PS best?
apanella
Post by apanella »
Before I went to SmugMug, I used "JAlbum" when I was maintaining my own site. Today it seems they have options for both License-only (including a free level) and "License + storage". I used license-only version and remember it as good/easy to use with the ability to create a wide variety of gallery styles.
siehorst
Post by siehorst »
Good morning,
syncrasy wrote: 07 Sep 18 14:32 ... I am already paying for my own web hosting service since I already design my own website ...
time ago I run into the same issue. But as my website-editor
https://www.wysiwygwebbuilder.com/
is offering lots of galleries, I don't miss this feature in PS anymore.
Isn't you editor offering this option?
horst
