Altitude is missing in New custom field info
kalain
Post by kalain »
In GeoTag panel you have Lat/Long/Alt (Ok).
In infos panel, you can customize and add custom field but altitude is not in the list !!!
I expected to find GPS Altitude just below GPS Longitude.
screen copy04-09-2018-11.26.12.jpg (91.19 KiB) Viewed 1271 times
Re: Altitude is missing in New custom field info
That drop down is organized the way the Image Details panel is organized.
You can find Altitude in Advanced -> EXIF Specific Properties Schema
