GEO-tagging on Mac
Guus
GEO-tagging on Mac
Post by Guus »
Just purchased Photo Supreme. Looks to be a very feature rich DAM which I want to combine with DXO instead of using LR. Been busy getting my images over from LR to PS but since some images are lacking GPS info I try to tag them in PS. This is not going very easy so maybe I'm doing something wrong.
Since I know where the pictures are taken I want to use the map to add a marker and then perform a reverse lookup. I can't seem to get the map moving like I want to. I prefer to use the street version instead of the satellite one. I have to double click the + or - to zoom in or out, in the normal Google maps you just click once. I also can't move the map around with my mouse. Only every now and then after clicking like a madman on the map there appears a little hand and sometimes it wil start to move the map. I use an Apple Magic Mouse 2, is this a problem for PS?
Also several times after clicking somewhere in the map and either clicking apply of switching to another photo the program jumps to a complete other folder then the one I'm currently in and selects it to edit the title. Not funny.
Hopefully someone can share his or her experiences with the Mac version on GEO-tagging with the map.
OldRadioGuy
Re: GEO-tagging on Mac
Post by OldRadioGuy »
I had the same problem, but I found holding down the Cmd key, then click-move with the mouse worked.
Photo Supreme 2025; DxO PhotoLab; Affinity Photo; PhotoLine; macOS Sequoia; Mac M2 Studio
Guus
Post by Guus »
Thank you! That works perfectl!
