Keyboard Shortcuts
MikeNaylor
Keyboard Shortcuts
Post by MikeNaylor » 18 Dec 17 10:56
I've just spent half an hour trying to assign a color label to an image. It turns out the manual is wrong. Hasn't anyone noticed this since its publication, or am I the only Mac user daft enough to trust my entire image collection to Photo Supreme?
On a Mac the correct shortcuts to change an image color label are Ctrl+0 to Ctrl+5 NOT Cmd+0 to Cmd+5.
This puts the fear of God into me, because shortcuts are the ONLY way to accomplish so many things. I'm incapable of remembering hundreds of key stroke combinations, so I dread to think what the outcome will be if I get one wrong. Its downright dangerous.
Apple iMac (Retina 5K, 27-inch, Late 2015), macOS High Sierra, Photo Supreme 3.4, Lightroom Classic.
Re: Keyboard Shortcuts
Post by Hert » 18 Dec 17 18:02
The manual is not wrong...the shortcut PSU uses for color labels are Cmd-0-5. But I understand what you intended to say: you recommend PSU to also use Ctrl-0-5
MikeNaylor
Post by MikeNaylor » 18 Dec 17 18:35
To change a thumbnail color label on a Mac, the manual says to use the Command key and a number key 1 through 5. This does not work. But if I use the Control key instead of the Command key, it does work. That is why I'm saying the manual is wrong.
Post by Hert » 18 Dec 17 23:40
Ah ok. Now changed in the document.
MikeNaylor
Post by MikeNaylor » 19 Dec 17 0:08
That's odd. I was rather hoping think you would keep the documentation and change to coding to use Cmd+Number. This would have been more consistent with the Mac way.
