DxO PhotoLab support
germie
Post by germie »
Hi Folks,
I'm using photo supreme 3.3.0.2606 with DXO PhotoLab.
In the settings I set DxO develop support to either elementary or approximately (doesn't matter for the outcome).
When I use u-point corections in a file the thumbnail is missing completely.
Instead of the thumbnail the following text appears: "{0.xyz...." is an invalid float
Crops bij DxO PhotoLab are not shown for any image.
Can anyone reproduce this and if yes, will there be support for DxO PhotoLab in the future?
Kind regards from Holland
Germie
Jure_13
Re: DxO PhotoLab support
Post by Jure_13 »
Hi Germie,
I can confirm. Happened to me when I imported two images from DxO PhotoLab on which I did u-point corrections. After I temporarily moved the .dop files away, Photo Supreme imported without a hitch and showed thumbnails.
Jure
Maybe you can attach a dop file?
germie
Post by germie »
Hi Folks!
Thanks Jure for your help.
Hert, I attach a dop file to this message.
I had problems uploading the dop file to the forum.
Therefore I renamed PC010485.ORF.dop to PC010485.txt
Germie
PC010485.txt
(67.05 KiB) Downloaded 562 times
Thank you for providing the needed file.
ColG
Post by ColG »
Just started testing Photo Supreme and I too use DxO PhotoLab. PhotoLab creates sidecar files as you know but it can be stopped from doing this. However whilst I have managed to edit raw images held in Photo Supreme in DxO I have not been able to get the thumbnail in Photo Supreme to update to reflect the changes made. If I use it to open DxO again the image is in the edited state that I left it but the thumbnail will not change in PS. Any ideas?
germie
Post by germie »
Until the update arrives that supports PhotoLab I think its best to set DxO Edits support (Preferences / File Handling) to "None".
Photo Supreme just shows the original thumbnmail of the raw file then.
You might need to refresh thumbnail, by selecting images affected and then pressing Ctrl-Alt-T
Germ Wind
roeslewf
Post by roeslewf »
Can we get a hint when this might be? Thank you!
Wolf Roesler
This sis something that happened relatively recently with one of the newer updates. I am not quite sure where the problem lies, with DxO or with PSu. The DxO edits previously rendered without any problem, but I updated both PSu and DxO a few times and and some point I started to notice those missing "invalid" thumbnails...
Trying to figure out a workaround I discovered thus:
An alternative is using DNGs instead of NEFs. The DOP files generated by DxO when you use DNGs are read by PSu without any problems. Also, if you do not want to convert your files to DNGs you can choose a different rendering method in PSu: If you set DxO support to "elementary" the thumbnails are apparently rendered without trying to read the DxO edits from the DOP file. All not ideal, but at least a workaround...
BTW - deleting the DOP files and re-creating the thumbs is another option though one then obviously looses the DxO edit settings.
germie
Post by germie »
I absolutely don't want to be pushy about this, but will a fix be available in the not-so-far-away future?
Kind regards
Germie
Post by jstartin »
germie wrote: 25 Jan 18 8:32 I absolutely don't want to be pushy about this, but will a fix be available in the not-so-far-away future?
Kind regards
Germie
Remember that, although Hert from IDI participates here often, this is a user-to-user forum and there are no users who know the answer to that.
germie
Post by germie »
I see your point. However, Hert picked up this issue from this forum and I supplied relevant files through this forum.
Hence my later question about the status here.
There will be support for that change DXO made in the foreseeable future
roeslewf
Post by roeslewf »
Is DXO Photolab now supported in new Version 4 of PSU?
Stubb
Post by Stubb »
As a DxO Photolab user, I'll add my name to the list of those looking for Photolab support.
