to speed up the synchronisation
Phosy
Post by Phosy »
On my client, the pictures and postgres db on the windows server 2012R2, the process of synchronisation takes very long time. 0.1% in appr. 20 Sek.
I have tuned the postgres db according the manuel!
Is there an other solution to speed up the whole thing. On the Windows Server as on my client, there is just arround 20% processor, if even so high. On the Windows Server as on my client, there is just arround 20% processor load, if even so high.
Phosy
Re: to speed up the synchronisation
Post by Phosy »
Ok. I have pushed up the Priority of the Process in the Taskmanager. one step more then normal is ok. two step more then normal causes a crash of PSu.
At least the synchronisation run now with about 40%, about twice of normal.
But it is not as fast as I would love it. ;-)
Post by Stephen »
I believe that you must get accustomed to the slow speed and do it when you are not in a hurry. I don't work for PSu, but I realize that it is carrying out many tasks. Just don't interrupt it.
I think you're mainly waiting for the file system. You may want to disable auto-sync to file and sync manually when convenient. If you're reading from files then you'll have to bit the bullet once to get everything read into the catalog database.
Phosy
Post by Phosy »
Just two additional questions:
There is the possiblitiy to write the Meta-Data in a side-care File. The other posibility is theses to write to the Picture-file.
Which one of these two methods is faster relating synchronizing?
And where do I define, that the side-cars will be created?
You can disable metadata writing by keeping the metadata in the catalog only.
