Red Eye and zoom -> Access Violation
Phosy
Post by Phosy »
When I try to remove red eyes an access violation happend.
I mark the file, then I go to "Adjust" - Filters - Red Eye Correction.
Mouse with cross to the eye and mark it as mentioned.
Everything is ok.
1. But when I zoom in, that the eye get bigger, than an access violation can sometimes occure.
2. Did I use the red eye correction, the switch on the right side is "on" . But when I switch off, so the green light goes out, but the red eye correction is still in the pictures.
So I ask myself, which version is more reliable the 32 bits Version or the 64 bits Version?
I'm using on this PC at the moment build 3.3.0.2604.pg (64 bits).
Phosy
Re: Red Eye and zoom -> Access Violation
Post by Phosy »
No Idea?
sanphotgn
Post by sanphotgn »
Over the years, I have seen the Access violation (0) error appear. It appeared the other day. Typically, I am just moving through my images, adding metadata via the Details panel, when it appears. My fix: I close out the database, wait a minute or two, open up the database, begin where I left off, and everything appears to be OK.
