Problems uploading to Zenfolio
Ruhell
Post by Ruhell »
For the last couple of days or so I've had problems uploading to Zenfolio, though sometimes it works...Is anyone else having any issues? Has Zenfolio changed anything?
I did upgrade my old computer from win7 till win10 this weekend, maybe that could be the cause though everything seems to be working brilliantly, and as I said - sometimes it works
I'm attaching a screenshot of the errormessage
Maybe a Mantis ticket or Zenfolio?
V....2072x64
Zenfolio 2015-10-22_214550.png (118.76 KiB) Viewed 5981 times
Re: Problems uploading to Zenfolio
For now it looks like their server is currently not running as it should. Sometimes I do get through fine, other times I get the error you're getting. I'll try again tomorrow
Post by weidmic »
I don't use PSU to upload images to zenfolio, but lately I run into lots of issues with zenfolio...
Ruhell
Post by Ruhell »
Thank You both, that would most likely answer the sometimes slow load/responsetime with Zenfolio. Hopefully They'll straighten it out soon
Ruhell
Post by Ruhell »
Looks like Zenfolio has quite a few problems with their programming and servers for the time, at least according to their forum
http://forums.zenfolio.com/categories/problem-reports
Ruhell
Post by Ruhell »
I got this answer on the Zenfolio Forum
Since 2009 we have been proud to offer an expansive and robust API for pioneering developers to make use of in building their own tools on top of Zenfolio. We’ve worked hard over the years to continually improve and refine the API and now we’re ready to take the next step by deprecating all versions of our API older than 1.7. Beginning 9/30/2015 all calls to API versions 1.6 and below will no longer function. We ask that you update all of your development projects to at least version 1.7 before then to avoid any problems for your users.
Please refer to our API guide at http://www.zenfolio.com/zf/help/api for the relevant changes you need to make. Should you need assistance visit feel free to ask in this forum for help and guidance using the Zenfolio API.
Thank you for your cooperation and help in providing useful tools for the Zenfolio community!
Link below, could You have a look at it, please
http://forums.zenfolio.com/discussion/1 ... ice#latest
Ruhell
Post by Ruhell »
