Sort by date/time in import view?
DarkStar
Post by DarkStar »
When selecting pictures to import, is it possible to sort them by date/time in the selection window?
My problem is that I'm importing images from two different camera apps on my phone, which use different naming schemes (date_time.ext vs IMG_date_time.ext, PANO_date_time.ext). This makes it kind of tricky to ensure I've imported all the images for a certain event, when the various blocks are interleaved.
My current process is to rename all the images using a common pattern (MyName_date_time.ext, from EXIF data), but this doesn't help until after the import process is finished.
Re: Sort by date/time in import view?
Above the thumbnails in the Import module there is a button to select or mark images by date. Could that be what you need?
