2 In Last Import in favorites
Larry56
Post by Larry56 »
I don' know how I did this, but I have two In Last Import selections in my Favorites. Both are the same as far as I can tell. I'm pretty sure I shouldn't have two. How should I get rid of one of these?
Re: 2 In Last Import in favorites
That's strange. Unfortunateley, I don't think PSU provides any standard way to remove In Last Import (not sure why). Feel free to open a Mantis ticket or vote for #2617 (button for clearing up all favorites).
You can delete it by clicking the star icon next to the Last Import in the CATALOG->By Catalog State
Larry56
Post by Larry56 »
Thank you. That did it. I looked all over to see if I'd accidentally starred but obviously missed Catalog State.
dpaine
Post by dpaine »
I managed to put three "In Last Import" items in the Favorites list.
Clicking the star next to "In Last Import" in the "By Catalog State" menu list removed one of the "In Last Import" items from the Favorites list (bringing the count down to two), but I have found no way to remove either of the two remaining "In Last Import" items from the Favorites.
Anyone have any suggestions? If there is no solution, is there a way to clear the Favorites list and start over?
- David P
Larry56
Post by Larry56 »
In my case I found that in my Filter dropdown there were a couple from Favorites that were still showing as a filter. By removing from Filter I was able to get my Favorites back to where I wanted.
dpaine
Post by dpaine »
Thanks, Larry. I do in fact see two "In Last Import"s in the filter dropdown, so that agrees with your experience.
Unfortunately, I do not know how to delete items from the filter dropdown list. :(
A little more help, please...
- David P
Larry56
Post by Larry56 »
I hate to admit this but I don't remember how I fixed it. I think I made sure none of the filtered items were options in the filter drop down and then deleted and renamed the color labels. As you can see my problem was a little different than yours but maybe they are related to yours.
sanphotgn
Post by sanphotgn »
You may have tried this or it may not be similar to your situation ... go to Favorites, click on the In Last Import you want to delete. The photos related to the entry should appear. Float your mouse over the In Last Import you want to delete, so In Last Import is highlighted and stays highlighted. Press the Delete key on the keyboard.
dpaine
Post by dpaine »
Brilliant, sanphotgn! Your process (click, mouse float, delete key) worked.
Thank you!
- David P
