I applied the "GEO Tag from GPX file batch" to some images yesterday. After launching PS today, I now see the below error message when selecting any GEO tagged image in my catalog. When selecting "Display on map" I always see the Statue of Liberty, although the correct coordinates are stored with the images. Any idea what went wrong and how to correct that?
Thanks and best regards,
Alfons
Problem after applying "GEO Tag from GPX file" batch
- Unbenannt.PNG (75.28 KiB) Viewed 5295 times
Re: Problem after applying "GEO Tag from GPX file" batch
I experience the exact same issue since a few days and will file a bug report in Mantis.
It looks like Google has changed something in their API. A fix is under investigation.
I, too, am experiencing the same problem. Workflow brought to a halt. Hopefully, it's an easy fix.
Google released an update of their. Maps API that broke compatibility in Windows Explorer. Update to the newest release of PSU (2066).
